mcintoshmc
Ok, I really need to replace my galvanized as the water coming out is brown at times, and don't want to hook up a washer and dryer till this is replaced. I was told when purchasing the home, that the rust should flush itself out, but it's been 4 months, and although it isn't as bad as it once was, it's still brown from time to time. I've received a few quotes, and know that I will not be able to pay for this for the foreseeable future, so I'm just going to have to do this myself. I installed my own sprinklers, so I'm going to have to do this. Got a family to think about.
After some research, I've decided to go with PEX, as its easier to install due to less fittings.
What are some crucial things I need to know and worry about?
I know that I will need to differentiate which pipe is cold and hot. How do I do this?
My basic thinking is that I can basically follow the current block diagram, and mimic it with PEX. Is there any flaw to this thinking?
It's a one story home, and I'm not prepared to put holes in my walls, so I'm thinking that I should leave the risers alone for now, and save that for in the event there is a kitchen or bathroom remodel. Will leaving galvanized riser defeat the whole point of this project?
I'm thinking that I can mimic the system without shutting any water off until it is time to connect to the water coming in, and to the risers. Is that the easiest way?
That's all for now, let me know if I missed something? Thanks in advanced!
