Replace old water supply valves with ??
Discussion in 'Toilets and Sinks' started by Bill Spratt, Jun 17, 2019.
  1. Jun 17, 2019 #1
    Bill Spratt
    Bill Spratt
    Bill Spratt
    Jun 17, 2019
    Brooksville, Fl
    Laundry sink water supply valves are very old and one (Cold) leaks intermittantly. Not a bad leak but would like to update with new ones. There is a 3rd valve coming off cold for fridge water run. Are there parts that I can purchase like shark bite fittings or do I need to sweat this stuff? It is all copper though the paint makes it look different in the picture. Any help at all would be greatly appreciated thanks - Bill
  2. Jun 17, 2019 #2
    Bill Spratt
    Bill Spratt
    Bill Spratt
    Jun 17, 2019
    Brooksville, Fl
    One more thing - the cold water slow leak was just behind the valve handle I guess you call "stem". Thanks again!
  3. Jun 17, 2019 #3
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,355
    203
    Boston, Massachusetts
    those are BRASS CRAFT valves should say right on the handle....you can buy replacement washers one (small)goes on the stem one (large )goes behind the large brass nut
    a plumbing supply house would have the washers
  4. Jun 20, 2019 #4
    SandburRanch
    SandburRanch
    SandburRanch
    May 1, 2019
    12
    usa
    I've stopped those leaks ( with the valve closed ) by removing the bonnet nut and coating the exposed stem with a liberal coating of plumber's grease then re-assemble the bonnet nut with about an extra 1/8 turn.
  5. Jun 21, 2019 #5
    Bill Spratt
    Bill Spratt
    Bill Spratt
    Jun 17, 2019
    Brooksville, Fl
    Thanks guys really appreciate the help; the good news is we havn't experience any leakage since posting. I am thinking of repairing as that is much easier. My wife sort of wanted "new fixtures" - so if anyone has ideas on whether or not (and how) to do this I'm all ears. Then I can make the best choice (happy wife happy life you know the drill)
Share This Page
