Removing threaded nipple from cast standpipe
Discussion in 'General Plumbing Help' started by Bill McLeod, Jun 26, 2019.
  1. Jun 26, 2019 #1
    Bill McLeod
    Bill McLeod
    Bill McLeod
    Jun 24, 2019
    Michigan
    Hey everybody, this is my first post. Im in the process of replacing 1 1/2 drain pipe coming from kitchen and draining to a cast standpipe in my bathroom wall. Im stuck at Removing a rotten threaded steel nipple from the cast standpipe. Any advice on how to proceed with this? 15615082671636421779658827533549.jpg
  2. Jun 26, 2019 #2
    CT18
    CT18
    CT18
    Apr 30, 2014
    501
    122
    Bloomfield Hills, Michigan
    Heat up the tee around the nipple.
  3. Jun 26, 2019 #3
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,373
    204
    Boston, Massachusetts
    another way is to cut the nipple close to the cast iron threads in a few places close together...then use a hammer and small chisel to remove the slices you cut that will leave an open space were you would use the hammer and chisel to somewhat crush the nipple so its smaller than the threaded opening and you should be able to pull it out.....this would be you last option just because you could damage the cast iron fitting if your not careful....
  4. Jun 26, 2019 #4
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,373
    204
    have you tried to use a pipe wrench and giving it a few good wacks with a hammer
    Diehard and SHR like this.
  5. Jun 26, 2019 #5
    SHR
    SHR
    SHR
    Member Professional
    Mar 5, 2014
    643
    294
    , Minnesota
    No serious attempt has been made to unscrew that nipple. Big pipe wrench and a lot of elbow grease usually gets it out. Old nipple is ALWAYS destroyed during removal so that one looks untouched.
  6. Jun 26, 2019 #6
    Bill McLeod
    Bill McLeod
    Bill McLeod
    Jun 24, 2019
    Michigan
    Sounds good. I will let you know how it goes. Thanks!
    SHR likes this.
  7. Jun 26, 2019 #7
    Bill McLeod
    Bill McLeod
    Bill McLeod
    Jun 24, 2019
    Michigan
  8. Jun 27, 2019 #8
    WyrTwister
    WyrTwister
    WyrTwister
    Dec 6, 2015
    136
    13
    Penetrating oil , before and after heat .
    As a last resort , Big Hammer and chisels , as has been suggested .
    Best of luck to you .
    Wyr
    God bless
  9. Jun 27, 2019 #9
    SandburRanch
    SandburRanch
    SandburRanch
    May 1, 2019
    12
    usa
    Unless it's a hydraulic nipple a pipe wrench has a real good chance of only egging the nipple. penetrating oil - don't waste your time. As previously mentioned, cut it off flush and then split it by sawing. If you are an X-pert with a saws all go at it. If not clamp a hack saw blade between a couple of strips of wood and cut on the pull stroke. You'll be able to feel when the teeth first contact a thread. If the length isn't cut off, one cut often does the trick using a couple of hammers, 1 as backup. Cut off, 2 cuts may be necessary.
    Not many plumbers have a Proto easy-out that size.
    phishfood likes this.
  10. Jun 28, 2019 #10
    Bill McLeod
    Bill McLeod
    Bill McLeod
    Jun 24, 2019
    Michigan
    20190627_203101.jpg 20190627_202908.jpg Awesome! 7 minutes of map gas on the collar and bingo! Thanks guys!
  11. Jun 28, 2019 #11
    SandburRanch
    SandburRanch
    SandburRanch
    May 1, 2019
    12
    usa
    Good job
    ,but You were lucky it didn't deform worse. If there is ever a next time consider putting a socket in the nipple to reduce the deformation some.
    Mikey likes this.
  12. Jun 28, 2019 #12
    WyrTwister
    WyrTwister
    WyrTwister
    Dec 6, 2015
    136
    13
    Good idea , using the socket on the inside of the nipple .
    Glad the heat worked ! :)
    Wyr
    God bless
  13. Jul 10, 2019 #13
    SHR
    SHR
    SHR
    Member Professional
    Mar 5, 2014
    643
    294
    , Minnesota
    Perfect. Nice job.
Share This Page
