JCGuitarDad
Hi all. Did a search for this topic, but didn't find one, so I've started my own.
I'm remodeling a second-floor closet in an old home (1905), which the former owners had sold with this capped sink plumbing left in the bottom of the wall. We use this room as a closet and had simply put something in front of the pipes before, but now that I'm covering the plaster walls with shiplap panels and putting in shelving, I need these pipes removed. Problem is, I can't find their supply line from the basement -- or it isn't specifically marked. I can't tell if these still carry water or not. Should I unscrew those caps? There is some play in the copper pipes, and it's possible they could be pushed back into the opening btwn rooms in the wall (est. about 8" gap) if I could bend them, but a bit afraid I might break them. And the drain pipe seems fairly fixed in its position. So, what's the protocol here if one can't tell if the pipe is "live" but needs to be removed? Thanks very much for any assistance!
