BobMaine
The farm I work on has a water system partially buried underground with a drain valve located in at the lowest spot in the system. Unfortunately, this valve is manually operated and is 200 yards from the barn. In the winter it has to be closed to pressurize the system then opened to drain the field to prevent frozen pipes. Walking to and from the valve in the deep snow isn't much fun so I would like to install an electrical valve that could be operated from the barn. I've looked on the net and asked some local plumbers but so far have not found a valve to do this.
Anyone have any info on a valve like this?
Thanks,
Bob
Thanks,
Bob
