Putting bellends on 2,3,4 inch pvc pipes.
Discussion in 'General Plumbing Help' started by H-MAN, Jun 16, 2019.
  1. Jun 16, 2019 #1
    H-MAN
    H-MAN
    H-MAN
    Jun 16, 2019
    Australia
    Hi new here jut like to know if there is a tool or way of putting a bell end (don't know what there called) on larger PVC pipes.??
  2. Jun 16, 2019 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,373
    204
    Boston, Massachusetts
  3. Jun 16, 2019 #3
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,373
    204
    i believe that's the hub you could cut the end you need off of a service weight(sv) its marked on the pipe use a transition coupling this coupling accepts both diameters....not
    a fernco coupling why do you need to o this???????
  4. Jun 16, 2019 #4
    H-MAN
    H-MAN
    H-MAN
    Jun 16, 2019
    Australia
    Yes think know what mean.
    but when use a half length of 4 inch PVC pipe.
    The other half pipe not got a hub on it.
    and then end up with lot pipe can not use.
  5. Jun 16, 2019 #5
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,373
    204
    I don't really know what your trying to do the pvc will clamp onto one end and you can pack and pour the other end or use a resilient gasket/push gasket
  6. Jun 16, 2019 #6
    SGkent
    SGkent
    SGkent
    Thank You
    Jul 19, 2016
    91
    7
    near Sacramento, CA
    you can buy them with bell ends or you can use couplings to join the pipes. Those are your choices. If you have say 50 pieces of pipe and don't want to use couplers then to put a factory style bell end on them you would need an extrusion mold and a way to heat them. Tools and time would cost more than the couplings. If you decide to buy them in 20' lengths then lets say you need a piece of pipe that is 4' long. Once you cut it you will need to use a coupling on the remaining 16' or throw it away. You will also need couplings and elbows, tees etc.. Bell ends are good when you are running a long straight length of pipe.
    [​IMG]
  7. Jun 16, 2019 #7
    H-MAN
    H-MAN
    H-MAN
    Jun 16, 2019
    Australia
    So there is no simple tool to heat and make a hub on Large PVC pipes??
  8. Jun 16, 2019 #8
    SGkent
    SGkent
    SGkent
    Thank You
    Jul 19, 2016
    91
    7
    near Sacramento, CA
  9. Jun 16, 2019 #9
    H-MAN
    H-MAN
    H-MAN
    Jun 16, 2019
    Australia
    Yes the small one's are easy to do.
    but is there anything that do 3,4,5 inch pipes??
  10. Jun 17, 2019 #10
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    368
    83
    Wouldn't it be easier and cheaper to simply buy couplings for each size you might be working on?
    breplum and SHEPLMBR like this.
  11. Jun 17, 2019 #11
    sawsaw
    sawsaw
    sawsaw
    Active Member
    Nov 24, 2010
    44
    Cottage Grove, MN
    Try googling for methods. I've noticed a few showing how to stretch or bend PVC piping...
  12. Jun 17, 2019 #12
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    774
    145
    NOKESVILLE, VA
    buy a coupling
    breplum likes this.
  13. Jun 24, 2019 #13
    Rossando
    Rossando
    Rossando
    Jul 2, 2018
    51
    8
    San Francisco
    Don’t try that, if you care about the repair done right you will use couplings, primer/glue. Many kinds to choose from if your going from cast iron to plastic use a misson band CP 44 or CP 33. One side is ment to go into plastic the other for cast.
Share This Page
