Mickuss
- Joined
- May 6, 2018
- Messages
- 2
- Reaction score
- 0
Hi Plumbers
Little help please. See attached pics. The poly pipe drawing from rain water tank pictured has burst 3 times now and repaired 3 times .
The pump draws water from rain water tanks and supplies the whole house.
At first I couldn't make sense of it 1. why there was heat 2. why there was pressure.
Every time I repaired and restarted the pump worked normally.
But now I suspect the pressure cut out is intermittently getting stuck on and heating up the water, and I suspect there must be buried check valves stopping increased pressure back into tanks and that pressure caused by heat can't escape.
Does this sound about right? Any other possibilities anyone can think of?
4 separate plumbers I've spoken to are as baffled as me
