Problematic Toilet Question
ToiletTrouble
Jul 25, 2015
I'm seeking some advice on a problematic toilet. It seems to be flushing fine, but not draining very well. It drains very slowly after it fills (but not overflows).
I have plunged, used an auger (found limited material that would be clogging), and finally used a CO2 cartridge based plunger to blast out a potential clog. After that, it seemed to work ok (for about 10 flushes) and it was back to the slow drain.
I checked the jets as well under the rim and those seem to be clean and clear.
I'm wondering if it's an issue with the mechanics in the tank itself? The water level in the tanks seems to be fine and fill properly after it's flushed. The flapper closes properly and in a good amount of time, the float ball seems to be ok also.
Any advice is greatly appreciated.
Thanks!
