Pressure drop in cold weather?
Gh0st
Aug 14, 2017
18
I have to do a 24 hour air pressure test but the pressure drops 4 psi overnight an part of the pipe is exposed to the cold elements.Is there a formula for finding how much my pressure could drop for every degree the outside air drops?
Thanks all in advance
PV=nRT. Is the standard gas equation. looks confusing but is pretty simple, because the only thing changing is the temperature and pressure, all else stays the same. Unless of course you do have a leak.
So P1/P2=T1/T2, the only hitch is the temperature need to be in degrees Rankin. But, you can convert from degrees F to R by adding 459.7 to the degrees F.
So Now you have the equation.
:PullingHair:
