Bathroom vanity is leaking from where the drain pipe meets the porcelain. The floor is drenched. How much would a handyman charge and is there some putty or something I could use to make it usable until I can get one.
Not a new install. Original construction, water tight for years suddenly leaking. Tried to upload video but no way to. Thinking seal worn out or something. Will upload eventually. Don't know why mp4 would be forbidden.
I can only speak to my experiences, but a plumbers license does not mean that they can fix things. I am not a licensed plumber or electrician (a license it not required in much of Vermont, unless it is a "public" building or on a public water supply), but I have done a LOT of repairs in the past 30 years. There are licensed plumbers around here that only do new work. There are not a lot of plumbers that are good at troubleshooting and repairing plumbing problems, or are even interested in doing repairs. A recent thread attested to that, when a poster was looking to know how to overhaul an old Delta shower faucet. A local licensed plumber wanted to just change the entire valve for $950. Those valves are easily repaired and a repair kit and labor is less than $100.
Even if they are licensed, doesn't mean that they know how to install fixtures and appliances. Those skills are not usually specifically required to get a plumbers license.
It is getting harder to find young people wanting to enter the trades. So be thankful that the problem was solved and he didn't charge a really exorbitant fee.
Woooo. Just because someone ever shows up with a lisence doesn’t mean they know what they doing. I knew what I was doing long before I ever let the state keep track of me. The good ones “get away with it” because there is never a complaint. And they take care of their customers. Why is he worth less then the high school drop out that works under someone’s license? And in the effort of admitting that plumbing eventually tears up. I cuss every jack leg that ever used caulk on a pop up. You know how hard it is to remove the flange once the brass corrodes below?. At least plastic comes out. Most homes change faucets every 10-15 years because they want too. So I need that pop up replaced in 20 minutes. No time to break 10 year old caulk then try to remove the rest. I just wasted an hour because someone doesn’t know how to putty. Then my freaking green horns grand daddy use to be a plumber. Now he put caulk on pop up, forgot to tell them to wait. Then I had to go back and completely replace drain to main because the caulk washed down drain first time customer used it. This is new work vs service. They aren’t the same. 1970’s era plumbing mixing with modern plumbing. Some stick with the 70’s some only know how to read instructions. Very few can adapt to both. Ok I get off my caulk box before someone says they caulk kitchen basket strainers. That’s even harder to get clean for a new one. Sry I rambled.OK. Went with the "plumber" for $175 and a good thing b/c it took him maybe an hour and a half to get the plunger to install and to get the trap off which was nearly impossible. So probably worth it this time. My unit was completely corroded and he didn't use any sealant anywhere. I thought it would never be water tight but no leaks I can see as of today. Oh and he wasn't licensed so it pisses me off that I paid that much and he wasn't even a plumber. How do they get away with that?
Tom - when you say you prefer brass, I am assuming that you are talking about the tailpiece. From that point, do you use metal trap or plastic? I far prefer plastic since it will not corrode. I have seen far too many metal traps corrode and leak out of the bottom of the U bend.If you buy a lavatory faucet at the box store it usually comes with a plastic popup that I consider junk. If you buy one at a
good plumbing supply house they come chrome over brass. Brass over plastic is the way I like to go. At least when I'm done
installing it with PUDDY I know its not going to leak....... Also when you are a licensed plumber there are things that you are aloud to do in the trade that a handyman is not aloud according to the Health Dept.
