Potable Water Sistern
Studhauler
Active Member
Jun 10, 2011
31
Audubon, MN
I would like to use a water cistern for my potable water supply, during periods of extended electrical outages. The info I could find about doing this, says to start with municipality treated water. I will be using water from a private well (raw water). That source says treated water is only good for two days in a cistern, unless one watches the chlorine level.
I am sure there are people out there that use raw water in their cistern. What are you doing?
Thanks for your help.
With a second source of water and also having a municipal system you will be required to at least have a back-flow device installed on the municipal water main, to prevent your unknown water supply from entering the city mains. This device will have to be tested yearly.
John
I only have one source of water, that is from my well. I am looking to put in a cistern, so that during period of extended electricity outages I can have running water without using a generator. The cistern would be empty 98% of the time. Only when commercial power goes out would i fill it, using my generator to run the well. Yes, a back-flow preventer would be a good idea so cistern water does not bac-flow into my well.
