autotech44
Hey guys.
I'm not a plumber but looking into selling pot filler faucets. Lots of complaints about connection leaks after install, and other seller's instructions all say use Teflon tape and you're good.
It's a 2" long, male/male, 1/2" nps/npt adapter. The npt end goes into the wall to the female fitting. The nps end is supposed to stick out a 1/2" from the wall where the pot filler screws on.
I tested it myself and both end's leaked with Teflon tape. I had to tighten heavy to seal the npt end, and way too many wraps of tape to seal the nps end.
A big issue I see is after the npt end is tight, you have to screw the pot filler in until it hits the included retainer. So it's never going to be tight on that end. The pot filler is held in position with a set screw.
What are the best instructions I can give a DIYer to install a pot filler. I hear tape, sealant, or both depending on who you talk to.
Thank you...
Thank you...
