Plastic Globe Valve Success?
boytonstu
Active Member
Aug 8, 2011
38
boynton beach, fl
http://www.ebay.com/itm/B-K-1-2-globe-stop-valve-grey-plastic-105-023-Lot-of-5-/231563886651?pt=LH_DefaultDomain_0&hash=item35ea48803b
These inexpensive 1/2" globe valves are unusual because they lack rubber washers to seal. Instead, the cylindrical stem seals against the valve body.
BTW What purpose is the plugged 1/4" threaded side hole used for?
Have you experience with this type of valve?
you dont want a globe valve. it restricks flow of water
http://upload.wikimedia.org/wikiped...-en.svg/1280px-Globe_valve_diagram-en.svg.png
http://www.nivzvalves.com/products/...Class-Catalogue-Drawing-Dimension-Diagram.jpg
http://www.valvestock.co.uk/files/21_dimension_small.jpg
ball valve is the way to go,,globe are crap
the water gets under the washer and makes it chatter
1/2" plastic ball valves are too hard to turn in comparison.
The restricted flow is not a problem.
It must be plastic.
Have you used these plastic globe valves without rubber seals?
When I first got into plumbing 20+ years ago, the company I was working for at the time used something that looked similar in CPVC. They were garbage, and they quit using them rather quickly.
The plug is a bleeder port for shutting down and relieving pressure downstream of the valve. That's why there is a flow indicating arrow printed on the valve. If you exercise a plastic ball valve before installation and grease it a little before installing, you will get better results when you need to shut it off in the future. Just the same as a brass ball valve. Some people just install them and find them hard to operate later.
Thanks for the pressure relief information.
A ball valve is not an option, the valve must have a threaded stem for the intended purpose.
Thanks, I don't know if the 20+ year old design is the same as the current builds.
Do you remember how the valves failed?
What valve was used for replacement?
As I recall, they would leak around the stem, in what would normally be called the packing. We went to CPVC solvent weld ball valves. The ball valves perform OK, if they are installed correctly.
Kind of a cross breed between a gate ( with the gate being cylindrical ) and a needle valve.
