Thank you so much for replying! It was a quick dry primer that dries in 30 minutes. Unfortunately, the walls went up right after the picture I took, but I was able to sneak in there through a hole behind my oven and clear 99% of the stuff off! Thanks again and have a great weekend.I think it is probably OK. It is likely quick drying, so solvents are gone and should then just be solids on the surface. You might even try a thumbnail to scrape dried paint off just for fun.
Thanks! I think it’s mostly Sheetrock in there, but I’ll run my hand under the PEX and make sure there are no rocks. Have a great week!more importantly, I would be getting the pex off those rocks before you close the wall up.
