Jeff Knecht
Is there better water flow connecting 1/2" pex to a R10000 valve that has 1/2" inlets and use pex adaptors, or a Delta R10000 that comes with
crimped pex inlets?
1/2" is connected to a 3/4" trunk lines , 9 feet away. 64 psi with 10 gpm. Would 3/4" run to the valve make any difference? There will be another R10000 for hand held but will not be usi
ng both at same time. Shower heads are both 2.5 gpm.
Thank you
crimped pex inlets?
Thank you
