Persistent Drain problem
Discussion in 'Drain and Sewer Cleaning' started by steveleb, Jul 6, 2014.
  1. Jul 6, 2014 #1
    steveleb
    steveleb
    steveleb
    Jul 6, 2014
    6
    I continue to have a bathroom sink that gets clogged up at least once a year. The sink shares a drain that is connected to the a/c condensation line not the over flow.
    Any suggestions?
  2. Jul 6, 2014 #2
    phishfood
    phishfood
    phishfood
    Well-Known Member Supporting Member
    Jan 18, 2010
    5,683
    965
    Orlando, FL
    Does the condensate drain back up at the same time, or just the sink?
  3. Jul 6, 2014 #3
    steveleb
    steveleb
    steveleb
    Jul 6, 2014
    6
    No, just the drain and it backs up into the sink.
  4. Jul 6, 2014 #4
    phishfood
    phishfood
    phishfood
    Jan 18, 2010
    5,683
    965
    Orlando, FL
    If it is not in the drain body underneath the sink or in the P trap, I would suspect backfall on the drain pipe that serves the sink, or some obstruction in the pipe (razor blade, construction debris, etc).
    Zanne likes this.
  5. Jul 6, 2014 #5
    steveleb
    steveleb
    steveleb
    Jul 6, 2014
    6
    Around 10 months ago I had a plumber come out and clean the drain. Then is started again two or three days ago. I don't know what could be causing the same problem so soon.
  6. Jul 14, 2014 #6
    rodeorooter
    rodeorooter
    rodeorooter
    Member Lifetime Supporter
    Jul 14, 2014
    5
    Sunnyvale, Sunnyvale
    Hydro-jetters are the preferred tools of plumbers who want to provide a full cleansing to a drain. Hydro-jesters are devices that place scalding hot water under tremendous pressure and then blast it out through a nozzle on a hose that reaches down inside drainpipes. The scouring action clears away clogs but also eliminates build-up along the pipe interior. This does an effective job of wiping away grease, fat, and other food particles that can coat the inside of pipes. Hydro-jetting needs the work of trained plumbers because of the potential danger from the high pressure water.
  7. Aug 2, 2014 #7
    mcgervase
    mcgervase
    mcgervase
    Superjet Sewer and Drain
    Aug 2, 2014
    Temecula, Ca
    If it's a 1 1/2 or 2 inch line, a cable is more effective against hair and hard blockages. Hydro jetters excel at grease and sludgy debris in pipes that small.
  8. Aug 2, 2014 #8
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    471
    150
    san diego, california
    make sure the plumber is using the right machine for the job. if he is using a little hand crank snake that is not the proper way to clean the line. i use a spartan 100 machine to clean lav lines and it works great. i disagree that hydro jetting does not work. it will definatley clean out the pipe.
    Zanne likes this.
  9. Aug 1, 2016 #9
    steveleb
    steveleb
    steveleb
    Jul 6, 2014
    6
    One more time the drain is clogged up when I use a plunger what I get up I a black looking stuff that looks like mud and a white looking like tissue paper. I had a clog buster out around two years ago and now it's back. First thing tomorrow I will call a plume to come out. This is the drain for a upstairs bathroom sink
    All the other sinks in the house drain fine including the toilets
  10. Aug 1, 2016 #10
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    471
    150
    Well your not gonna get mud upstairs and it could be just sludge your getting out
  11. Aug 1, 2016 #11
    Zanne
    Zanne
    Zanne
    Mar 23, 2013
    1,561
    178
    Do you have someone in the house who puts on a mud mask and then washes it off in the sink?
    Maybe someone is putting stuff into the sink that shouldn't go.
    Another possibility is that the plumber missed something when cleaning it out. have you taken apart the trap to check in the trap and see if any crud is staying in it?
    Also, is it possible the sink's pipes are not properly sloped so debris might be sticking inside them instead of being flushed out?
  12. Aug 1, 2016 #12
    steveleb
    steveleb
    steveleb
    Jul 6, 2014
    6
    No on the mud mask Yes I have taken the p trap and it is full of stuff mud looking and tissue looking soft junk could the stuff be a form og age caused by the ac drain
  13. Aug 1, 2016 #13
    Zanne
    Zanne
    Zanne
    Mar 23, 2013
    1,561
    178
    Hmm... Maybe someone accidentally dropped tissues or toilet paper into the sink and it went down? That could have caused dirt to build up. Not sure if the AC would be draining stuff like that.
    If you have kids it's possible one of them has been stuffing things in the sink that they shouldn't be.
  14. Aug 1, 2016 #14
    steveleb
    steveleb
    steveleb
    Jul 6, 2014
    6
    No kids no tp
  15. Aug 1, 2016 #15
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    471
    150
    Are you in a home or condo? is there a sink behind your sink? Ac unit is not going to leave black sludge. It will be a slime or calcium
    Zanne likes this.
Share This Page
