Perfect Pressure Pumps newest feature!
PhilT
VFD and Pump Expert
Apr 3, 2017
16
6
Orlando, Florida
P3's newest feature prevents pump damage caused by cavitation.
Cavitation protection is nothing new and many competitors simply shut the pump down when it occurs. Others do nothing and simply allow the pump to self destruct.
Cavitation happens when the water supply can not keep up with demand. The pump can only boost water pressure, not produce water. If you turn on several showers at once, you could starve the water supply to the pump and cause this.
While many of our competitors will shut down the pump when this occurs or worse, ignore it, P3 is much smarter than that...
P3 will automatically reduce your pressure set point until the water supply can keep up with demand. It will keep this set point until the demand goes away, automatically raising the set point back to the original pressure!
This is a DRAMATIC improvement to simply shutting down the pump.
A cavitating pump sounds like a pop corn maker and the sound you are hearing is little micro explosions as the water gets vaporized on the suction side (inlet) of the pump. This vapor is carried over to the discharge side (outlet) of the pump, where it no longer sees vacuum and is compressed back into a liquid by the discharge pressure. These explosions will "pit" the pumps impeller and eventually destroy it.
At TAW we are constantly improving our technology, it's our promise to you that you will not find a more advanced pump on the planet.
To stay up on all the pumps improvements as we constantly set new benchmarks in our industry, follow our FB page:
https://www.facebook.com/perfectpressurepump/
Thank you to all those that realized purchasing quality pays off in the long run.
Phil
