Pardon my ignorance...what is this?
Discussion in 'General Plumbing Help' started by Btseagle98, Sep 14, 2018.
  1. Sep 14, 2018 #1
    Btseagle98
    Btseagle98
    Btseagle98
    Sep 14, 2018
    Lawrenceville, GA
    Just bought a new home. I came from a ranch on a slab and did not have this contraption.
    This is located in my basement utility room next to my hot water heater, and I have no idea what it is. Any thoughts?
  2. Sep 14, 2018 #2
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    315
    40
    Bathroom in the basement? If so, that's a sewage ejector.
  3. Sep 14, 2018 #3
    Btseagle98
    Btseagle98
    Btseagle98
    Sep 14, 2018
    Lawrenceville, GA
    Not in the basement bathroom, but in a small utility room right beside the bathroom.
  4. Sep 14, 2018 #4
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    315
    40
    Yeah, it's for the downstairs bathroom. It carries water from the pit up to the sewer line. It's a pump for your downstairs bathroom.
  5. Sep 14, 2018 #5
    Btseagle98
    Btseagle98
    Btseagle98
    Sep 14, 2018
    Lawrenceville, GA
    Thanks! Had no clue.
  6. Sep 14, 2018 #6
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    88
    15
    Maryland
    It just looks to me like a regular sump pump next to a radon pipe. I have an exact setup like that in my utility room.
  7. Sep 15, 2018 #7
    chiraldude
    chiraldude
    chiraldude
    Hardcore DYI-er
    Nov 16, 2013
    104
    24
    Southern Minnesota
    Assuming it is sewer ejection from the basement bathroom but it could just be a sump for the basement foundation drainage. Either way, you need to know about it and how it works because if the pump inside there fails, bad stuff will happen. If it is a sewage ejector, you need to be very careful about what goes into the basement toilet. Nothing but you know what an TP, no exceptions!
    Your inspector and/or seller agent should have explained this to you.
  8. Sep 15, 2018 #8
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    315
    40
    I'm not saying this to be rude to anyone. It has a vent line coming off, with no obvious signs of being a radon line. Most radon lines have a detector on them, directly on them. This is exactly what I said, a sewage ejector. Don't make it more complicated than it is.
    TomFOhio likes this.
  9. Sep 15, 2018 #9
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    315
    40
    If you see some sort of red looping thermometer deal on any part of that line, yes, that's radon. If not, ignore anything to do with radon and it's a sewage ejector.
  10. Sep 15, 2018 #10
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    88
    15
    Maryland
    I've seen sewer ejector mechanisms and I really don't think that is it. I have never seen a sewer ejector mechanism that is not directly attached to the toilette. Here is my below near identical setup for both sump and radon.
    I have seen many RADON setups and never even once seen one with any sort of detector or any other sign that it is RADON other than some simple writing on the pipe.
    [​IMG]
    This pipe says "RADON".
    [​IMG]
  11. Sep 15, 2018 #11
    fixitron
    fixitron
    fixitron
    Feb 22, 2011
    59
    24
    Warren, VT
    That 2" pipe is too small to be for radon mitigation. It is more likely a vent pipe. A radon pipe should have a U-tube manometer to show that the fan is actually pulling a suction. It is NOT a radon detector.
  12. Sep 15, 2018 #12
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    315
    40
    There is a rubber plug on the top where the cord comes through. Pull it up, turn on a faucet in the bathroom and see if either the pump kicks on or you hear water coming in. If so, it's a sewage ejector.
  13. Sep 15, 2018 #13
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    88
    15
    Maryland
    All a radon pipe is is a vent pipe. It vents gasses from below your house above it to the atmosphere. While you could have a fan it is not required. Mine does not have a fan.
  14. Sep 15, 2018 #14
    mike fiore
    mike fiore
    mike fiore
    Aug 18, 2018
    120
    28
    exeter rhode Island
    it is a sewage or sump pump. there is a check valve on outlet. that is to stop water that has been pumped out from coming back into pit.the bigger pipe is a vent to keep pump from vapor lock.
  15. Sep 16, 2018 #15
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    737
    168
    Mansfield,, Ohio
    Does your main drain from upstairs go out above the basement floor. It probably does. The bathroom in the basement
    will drain into the black pit and then get pumped out to the main drain. Just like Justin said.
    mike fiore likes this.
Share This Page
