I am attempting to install a new p trap under my bathroom vanity. The pervious parts have basically completely corroded through and we went and purchased new plastic parts. The old ones were chrome. The waste arm on the replacement set is one of the long ones that slides into the drain. The problem. We are running into is that once the actual trap is installed, it comes out about half an inch forward too far to properly align with the tailpiece
The old set up there was a metal 90 degree elbow installed onto the main drain to which the trap was installed. With this set up everything aligned perfectly. The problem we are facing is that it appears when joining the trap and the elbow, it's 2 threaded ends trying to go together which does not work. I will attach a pic. Anyone know how to attach these 2 things. Otherwise like I said the trap shoot about 1/2 an inch forward of where the tailpiece is.
