Finally getting around to replacing some drain/vent pipe for my washing machine. The 1 1/2" sewer branch line is buried in the basement concrete floor. As you can see from the pic, there isn't much "stub" above the ground. I cut the sole plate to give a bit more room.
I wish to remove those fittings and expose the sewer pipe to make a straight line up to join into the vent and accept the washing machine drain as well. If I understand my options, I can:
1) cut the fitting leaving the bell and then make careful cuts in the fitting down to the sewer pipe without cutting the pipe and then pry away pieces of the fitting,
2) heat up the fitting and try to pry it off,
3) ask the good people at Plumbing Forums for solutions that I have no way of knowing
I guess I'm a bit (no, a lot) worried about damaging the sewer stub. Almost all how-to videos show removing pipe from fitting, not fitting from pipe. Hammering away with screwdrivers and chisels and heating up things all sound like a recipe for disaster. Which, by the way, leads to another question: Let's say the sewer stub is damaged, what needs to be done then? Thanks
