shooteneq1
Active Member
I have a shower remodel I am doing and have a plumbing question. I am redoing the walk in shower and have the floor dug up and removed and need to remove the old drain and connect a new PVC drain for tile. I think this is a cast iron pipe. How do I go about correctly installing a PVC pipe to the old drain? I have been trying to remove the current drain with no luck and might end up needing to cut the thing off. If I have to do that what is the correct way to connect the new pvc system to it. I want it to be done as right as it can be with no potential for leaks as I am in Florida and don't want the potential for small amounts of water leaking under the slab due to the amount of subterranean termites we have down here. I asked a guy in the plumbing department at Lowes and he said to sink a new pvc pipe as far as I can into the old drain but that just seems wrong on so many levels as that would not create a waterproof seal where they come together. He said you then use plumbers putty around the pipe where it meets but this just seems like a hack way to do it, but maybe its not that's why I wanted to get some professional advice on how to do it right.
