ok so just replaced kitchen sink plumbing.. now wont drain
icex48x
May 6, 2011
asdf, nc
Just replaced the plumbing under my kitchen sink. had a few leaks but was really just old and needed replaced.. So i replaced all the pipes under my drain to the wall.. Now my kitchen sink wont drain. its acting like theres a clog in the pipes in the wall because i when i undo the pipes at the wall most of the water comes from the wall pipes..
confused because it was draining fine before.. I tried plunging and snaking it.. snake i had wasnt very long so if clogged may not have reached but still not sure thats the problem as it was draining fine before...
any idea's?
edit: wasnt sure if i should post this here or not since i wasnt sure if its a clogged pipe or not..
Something may have broken loose and clogged an already choked down drain pipe. Are you sure the snake was going down the drain and not up a vent?
Otherwise, no other suggestions without seeing it. Might be time to call a plumber.
