occasional localized septic smell
Discussion in 'General Plumbing Help' started by fixitron, Feb 22, 2011.
  1. Feb 22, 2011 #1
    fixitron
    fixitron
    fixitron
    Feb 22, 2011
    15
    Warren, VT
    I have been doing general repairs, including lots of plumbing and septic, here in Central Vermont for over 20 years, so I am quite experienced. I have a client that bought a house last April. Two story chalet, slab on grade, built in the 1960s, 2nd home used on weekends (family of 4). They started noticing a septic smell, limited to a utility closet, starting about 6 weeks ago when they started a fire in the fireplace.
    The smell is only coming from this one closet that holds a sealed combustion, wall hung boiler, the pressure tank and the stacked washer/dryer. The closet is under the center staircase and is off the master bedroom and is centered on the south wall of the house. The only DWV piping in the closet is a drain for the washing machine that goes down into the slab (with water in the trap), and an 3” ABS cleanout in the floor.
    There are two full bathrooms on the NW corner of the ground floor. There is a hole in the slab below the bathtub for its trap (stone & plastic VB are visible below slab)- there is never a smell here or in either bathroom. The kitchen sink (on second floor) drain enters the soil stack above the west bathroom, almost at the west wall. Therefore, there is no other DWV piping above the slab within at least 10 feet of this closet (again, the only place with any septic smell).
    The only propane piping is for the boiler, and that comes right through the outside wall to the boiler. The second stage regulator is on the other side of this wall, outside. I carefully checked all of the joints, inside and outside, of the propane piping and regulator with my Bacharach Leakator Jr. and found nothing. It is not propane.
    I depressurized the house with a blower door to -50 pascals with respect to outside, and did not smell any septic, until we flushed the toilets and dumped the lav sinks all at the same time. The smell took a couple of minutes to appear, but it was only in that closet under the stairs. We repeated this later, without the blower door, and got the same smell after dumping water. When we did get the smell, my Leakator Jr. would start ticking only at the base of the stem wall in that closet. I tried sealing the slab/stem wall joint but we still get the smell from time to time, especially after dumping a bunch of water (such as this past weekend after several showers in a row).
    I had a local septic company check the pipes for cracks with a video scope (the same company that pumped the septic tank last April and also had inspected both IN and OUT pipes to tank. This time, they checked the pipe from the floor cleanout to the tank and from the cleanout to where it started branching to various fixtures (again, this is all piping under the slab). The only question was the condition of the cast iron pipe to the tank (which would be about 45 years old) and the condition of the joint between that cast iron pipe and the ABS building drain that connects to it. This is the only possible scenario that I can think of- a leak in the cast iron or the cast iron/ABS joint that is allowing septic gases to flow through what must be sandy soil to the house.
    We also ruled out any floor drains. The owner was present when the carpet was laid and there were no floor drains in the slab.
    We have clearly ruled out a dead mouse or anilmal.
    I did a smoke test of the piping (closing off the top of the soil stack) and found nothing.
    Short of digging up and replacing the building drain, which would be difficult to do now with a few feet of snow on the ground and temperatures in the single digits, does anyone have any other ideas on what the source may be or how to find the source?
  2. Feb 22, 2011 #2
    phishfood
    phishfood
    phishfood
    Well-Known Member Supporting Member
    Jan 18, 2010
    5,683
    965
    Orlando, FL
    Have you tried plugging the drain for the washing machine with a rubber expansion plug and then dumping all of the fixtures? If there is a venting problem that is causing some gas to be forced out of the washing maching drain, this would indicate that.
  3. Feb 23, 2011 #3
    fixitron
    fixitron
    fixitron
    Feb 22, 2011
    15
    Warren, VT
    That's not it. Absolutely no smell from that standpipe. Today I plugged the soil stack with a test plug and dumped hot water with peppermint oil down the kitchen sink. No smells. Then I flushed two toilets and drained two lave sinks of water all at the same time. Several minutes later I could detect a faint odor of peppermint at the edge of the patch around the cleanout. I suspect that the cleanout and some of the building drain was replaced not too many years ago. The slab around the cleanout looks like it was patched in after the slab was poured. I am still suspecting a leak in the pipe to the tank and the vapors are somehow going through the soil along the pipe and coming up through the slab.
    I have not smelled any septic today or last Thursday when I smoked the DWV system and put slight pressure to it, even after dumping a bunch of water. The client did smell it on Sunday when they were up, after several shower in a row were taken.
    BTW, when I pulled the plug off the top of the soil stack today, there was a strong odor of peppermint (**** never smelled so good!). I did not smell any peppermint on the outside of the wall of that closet, not that I expected to smell anything. The ground is quite frozen even next to the stem wall.
    I am going to see if I can clean out the crack around the concrete patch around the cleanout in the slab and patch it with hydraulic cement. Then I will see if the client still gets the stink from time to time.
Share This Page
