I’m currently planning on installing a Sioux Chief flange inside a 4” pipe on a newly tiled floor. The floor is 1-1/8” plywood subfloor>ditra>porcelain planks. The porcelain tile isn’t perfectly tight to the pipe, so as the flange sits, the flange screw holes sit right on the edge of the tile in a few spots. A few questions: will this compromise support of the toilet?I know the weight of the toilet isn’t all on the flange but wondering if it could still be an issue. Also, do I try to drill through the tile with a diamond bit or just notch the tile with a grinder? It seems that even if the tile was more snug, if I drilled a hole for the screws to pass through, the hole would be so close to the edge of the tile that it would probably crack eventually anyway. Should I possibly consider using a different flange that is a bit wider? Thanks for your help!
