yeto
Hi,
I have a submersible pump/bladder tank system. Sometimes during heavy water use (both showers running at the same time) the water will stop completely without warning then after a few minutes it will come back full force. My plumber replaced the bladder tank which didn't make a difference. He says he is not sure what is causing the problem but thinks it may be the well/pump. He says he is not a well/pump plumber so he can't do anything else to help me.
Also, when the water stops I can hear water rushing into the hot water tank. After 15-30 seconds I no longer hear the water going into the hot water tank and a few minutes later the water is back to normal.
Would someone be able to offer some advice as to some things I can check to determine what is causing this problem?
Kind regards,
yeto
Kind regards,
yeto
