Roffensian
Hi all, sorry to be the guy who registers just because I have a problem, but... I have a problem!
Living on an island in the Caribbean where our water comes from a rain catchment cistern. Pump keeps a pressure tank between a given range and water leaves the pressure tank to go through a three filter system - two cartridge and one UV. There are no pressure valves on the filter housings. There are shut off valves immediately before the intake to the filters and immediately after the outlet.
Today I changed the two cartridge filters by shutting off the two valves and then unscrewing the housings. First time I've had to do it here, although changed cartridge in a single filter system at a previous house many times. I also unscrewed the third housing (the UV one) because I wasn't thinking. Changed the filters, screwed the cartridges back, including the UV, opened the outlet valve, opened the inlet valve and heard the water surge from the pressure tank into the system.
But...
I now have no water from any faucet / toilet. It's like there's an airlock in the filter housings. I've tried removing and reattaching, I've turned the water back on with all faucets in the house open - nothing. Can anyone point me at what the problem might be?
Thanks in advance!
But...
Thanks in advance!
