Cannon123
Hello-
I recently attempted to replace an old Phister diverter with an identical part identified at the plumbing supply store. After install, the new one drips from the front (see attached picture) from around packing nut. It does not leak from the back and screws in fine behind. I have tightened packing nut but it will just cause handle not to move. I tried swapping the new 'screw plunger' handle with seal on end into the old diverter housing and having same problem.
The only thing I havent done is removed the old , I dont know what is called, brass seat nut that is screwed inside the old pipe and I assume creates a seal with the plunger. I cleaned out the area with CLR and it is clearly identical to the 'seat nut' that came with the new part. So I see no reason to replace it. And again, it is not leaking from the front, it is leaking from front. See attached photo. Thanks anyone for help on this one!
