beckman
I have a 50 year old shallow well with a vertical jet pump from Gould’s. The pump is attached to what looks like a 2 inch pipe that goes down in the 4 inch steel casing. Well company installed the pump without a seal. Does someone make a seal that fits around the 2 inch pump pipe so the pump doesn’t have to be removed to install the seal? Leaves and dirt are falling in between the 2 inch pipe and well casing. Any advice is appreciated.
