Jim Jensen
this is because I am replacing the PVC check valve, with a bronze one, it takes 2, 3 or more minutes, for the pump to build pressure, when I turn it on, so I am hoping a new check valve will fix that ?? It runs fine, once it gets primed and starts pumping water. I have pics of the material I broke off UNDER the check valve, I am thinking it is some kind of special mix of concrete, or epoxy ??? it chips strangely, not like regular concrete, and it is dark grey, and very fine material (not coarse like regular concrete, I mean.....) anyway, thanks all for any and all advice !!!
this is in Jacksonville, FL area, so likely very shallow well
