Need help with a comparison on cost for labor
amuscato
Mar 6, 2019
plainfield illinois
Need a price comparison on changing the before to the after
I see 2 things that are bugging me
you need 5 pipe diameters from pump to offset
to negate turbulence at the impeller
and you need vibration isolation [flex connectors] on the connections
the vibration of that motor will start the pvc to leak
I am quite familiar with pool plumbing and that is one of the sloppiest jobs I have ever seen.
I saw only 3 pics. What is the "after"? A new filter? A complete redo?
Ah ok I see now you replaced all your ball valves with Jandy never-lubes. Valves alone are $50 or so each. Plumbing for them looks easy just cut up a bit of cement. Materials $300 max. Maybe 1 hour of time. I'd say should be no more than $500. Depending on the market could have been up to $1000. Small job so many would charge more than it is worth to make it worth their time to come out.
How bout this? Tell us what you paid and we’ll tell you if you got took?
The new work is exemplary in its execution. Potentially took some careful time to chip away at the concrete to expose enough pipe.
I personally would prefer unions over couplings so close to the slab.
Unless the drive time is a factor, anything over $1,000. would be fair.
Yeah, unions would have been tight. A grand give or take would have worked. Heck, you’d have 30 bucks in CC fees alone.
Funny, he hasn’t been back. I wonder how much he paid.
