I have a newer clawfoot tub with a vintage look that has a telephone faucet with dual temperature control handles. The problem is the temperature does not get warm enough to take a comfortable hot bath. In our other shower I was able to figure out how to adjust the control valve in the cartridge, but cannot find a similar feature in this tub hardware. So we really haven't been able to use it for the years we've had it.
I've linked the tub and the parts sheet below. I started to dissemble it but was not able to remove the cartridge. Am I just not using enough elbow grease? Should I assume it screws out or pops out? Also, should I expect that this cartridge has a similar hot water adjustment feature that my delta shower has, or would that be somwhere else? The left handle is the hot side.
https://www.vintagetub.com/randolph...-faucet-with-fixtures-savingspackage01rc.html
https://www.vintagetub.com/download/Parts/English_Parts.pdf
I want to do something special for my wife because I know she'd really like to be able to relax in this tub. I'd really, really appreciate your help!
Thanks!
Brien
___________
Update:
I contacted the distributor and according to the support member (who had to ask someone else) there is no temperature control / safety value on the cartridge for this faucet. They said it delivers water at whatever temperature it gets from the water heater. If that is the case is there anything that would make the water from the tub faucet not warm enough when the shower right next to it gets plenty hot?
Thanks!
Brien
___________
Update:
