Greetings all,
My house was built in 1952, iron pipe and ancient (now dripping) fixtures. I've been unsuccessful in finding replacement valves for the shower (dual-handle, 8" split) so I'm debating pulling it all out from behind and putting in a modern single-handle valve and a new head.
Here's a front view:
and here's what it looks like from behind, through the bedroom closet:
I'm pretty handy and not afraid of my torch but I have a lot of newbie questions:
1. The pressure-balancing valves seem pretty big, is that 2x4 going to be in the way?
2. I can get under the house, so I'm assuming I'll be able to unscrew the elbow and put in a dielectric union -- any advice on that? My biggest fear is that I won't be able to unscrew the decades-old pipe
3. Is it better to attack this from the front or the back? Since I want to move to a single-handle valve, I expect that I'll have to replace a few of the tiles but I'd rather not knock out enough to require a Smitty plate
4. Is that a bond wire running across the back? If so, how does that need to be connected to the new pipe?
5. I think I can bust out enough plaster to get the new pipes under the house, but how do I handle the run up to the shower head? Can I put the elbow on it and then run it up the wall, or do I need to bust it out all the way up so that I can brace the pipe at the top?
6. What's the best order to piece this together? Can some of the elbows be sweat on before installation, or do I work bottom to top, sweating on each piece in turn?
7. I know nothing about new valves -- can someone recommend a) the type of valve to get, and b) specific brands? I've seen Moen recommended here, and read that Delta is okay; I've also read that Kohler changes their products so frequently that it may be hard to get replacement parts 10+ years down the road -- true?
Thanks very much in advance!
Mike
Mike
