All,
I was wondering if someone could help me with some advice on how to remove and replace my tub spout. I just bought a house, and there is about 1/4" gap between the spout and the wall. I probably could just put a lot of caulk in the gap, but that didn't seem like the right thing to do. There is a notch underneath the spout where I believe a set screw should be, but there is no screw there - so I'm assuming this is a threaded spout. I tried to unscrew it, but it won't budge. If I really twist on it I hear the pipes in the wall start to make noise (like they're shifting), so I stopped trying to remove it at that point. Is this normal, should I just stop being too cautious and just get out a pipe wrench to twist it off? Any advice would be helpful? Maybe it's plumber time? Also, I'm assuming that I can find another spout that is an appropriate length to eliminate the gap - is this reasonable?
Here are some pics:
Thanks.
Here are some pics:
Thanks.
