Moved into new house, stand alone shower drain leaking
Discussion in 'General Plumbing Help' started by JohnnyB1981, Oct 20, 2019.
  1. Oct 20, 2019 #1
    JohnnyB1981
    JohnnyB1981
    JohnnyB1981
    Oct 20, 2019
    Nj
    3 months after moving into a house and noticing kitchen ceiling dripping water every time wife takes a shower, ripped off the drywall, noticed it has been repaired multiple times, probably to cover up the leak, and see what looks like a flange that's too big or a pipe that's too small for it and packed with something? Would I need a whole new shower since from the top as well, almost looks like they melted something around it instead of repairing it properly in the past? Appreciate any help.
  2. Oct 21, 2019 #2
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    929
    202
    Mansfield,, Ohio
    If that is a standard shower drain then you should be able to replace it with a Jones Stephan's drain. Especially since you can get to
    it from the top and bottom. Look it up and there are some videos that you can see how its hooked up.
  3. Oct 21, 2019 #3
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional Lifetime Supporter
    Jul 21, 2011
    3,277
    746
    Melbourne, Florida
    That looks like the shower base is cracked.
  4. Oct 22, 2019 #4
    Rickyman
    Rickyman
    Rickyman
    Feb 5, 2018
    151
    58
    That drain fitting is probably sized for pvc/abs/cast iron. The OD of copper is smaller so they tried to seal it with epoxy or resin.
Share This Page
