Quantcast
Main water line part identification
TheShape
Nov 16, 2020
Haddonfield
Does anyone know the purpose of this part? It's on the lower right in the 2nd photo. I just noticed today that it is dripping. (We moved in a few months ago.)
There is what feels like a piece inside the end that is dripping that is shaped like an X. I was able to turn it with a screwdriver and it let water out. Would it be OK to cap it?
Thank you!
havasu
Administrator
Staff member
Admin
Jan 5, 2010
9,779
1,519
Southern California,
Since this is a speciality, I reached out to a former admin here. Chris works on and rebuilds these systems all over California and Idaho.
He said "Thats a typical RPDA device (reduced pressure detection assembly) different from a backflow device, this will bleed off pressure if the private side is higher than the supply side. That chingadera on the lower right must be a thingamajig because I have no idea what it is"
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,542
461
Boston, Massachusetts
This is back flow preventer it's either on your water main feeding your house or your lawn irrigation,there are 2 check valves( they look like they are at a 45° angle the part that's dripping is the relief valve,
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,542
461
Sorry got called away so that device seperates drinking water and water from another source like lawn irrigation,chemical feeds for boilers or cooling tower the house or street side is drinkable water and after the device it is used for non consumable applications.
They are tested (if registered a couple of times a year,a licenced plumber had to make repairs . After looking at the pics again the close up looks like a pressure
Relief valve above that is the backflow device
breplum
Professional
Professional
Nov 14, 2017
857
340
Lafayette, CA
for clarity, that top picture is an old "pressure relief valve".
Geofd's sentence made it hard even for me to get.
TheShape
Nov 16, 2020
Haddonfield
Thank you all for the responses!
I would imagine it's normal for the old pressure relief valve to drip? It hasn't stopped since I noticed it. It's maybe a drop per minute.
My sprinkler system valves are on the side with the old pressure relief valve.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,542
461
My fault though the releif valve on the backflow device was leaking, but it was the old pressure relief
HWSleuth
Nov 19, 2020
48
25
Texas
Put a gage on and take a pressure reading. Is there a pressure rating on the valve? If so compare pressure to valve’s relief point. Maybe valve is functioning to relieve pressure as designed. Maybe simply a leaking valve, replace it.
TheShape
Nov 16, 2020
Haddonfield
I don't have a gauge and don't see a pressure rating. Just the CII, Cll, or C11 on the one side and USA on the other. I'd replace it, but I don't know what it should be replaced with because I couldn't find another valve that looked exactly like it online.
