kurtminus
Hi All,
I live in a house built in the 1940s. Original shower controls were two knobs. Amazing water pressure, completely magical. I've never experienced anything like it, truly remarkable!
Landlord just had to re-do the shower due to a leak. They replaced the old two-knob system with a new Delta Monitor 13 single-lever. Appears to be this product: https://www.deltafaucet.com/bathroom/product/T13020.html#documents-and-specs Specifications of that product say "1.5gpm max flow" and you can tell.
There does not appear to be any restrictor in the new pipe from the wall, and I am using the same shower head as before, which also has no restrictor of any kind. The only thing that has changed is new pipes and a new shower valve. But the water pressures is GREATLY reduced from the old two-knob system. Luckily it's not terrible, but I used to be able to power wash, it was amazing. But no more.
My question is, what can I do? Is it possible to modify the new Delta Monitor cartridge for higher flow? Can I replace the Delta cartridge and lever with a higher flow model? I'll get this thing on the black market if I have to, not a fan of low water pressure.
Any advice would be great. Thanks!
