Cherokee513
So i have a shallow well jet pump, with a 52 gallon pressure tank. My issue is my pump will not build up pressure to the cut off (40-60 switch) It stops around 45 or 50 psi. This is the main source of water to my house. It comes from our cistern and we have a pipe coming from the ground in the bathroom, thats wat goes to the pump. I've attached pictures of my set up to see if everything looks normal. Any help, ideas, tips would be greatly appreciated!!! Its been this similar set up for years, and out of nowhere it started doin this, so i decided to redo everything to eliminate any problems and its still the same.
