I am having some issues with my septic system and am hoping to find some ideas or advice here.
The system was installed in 1992. I am not certain, but believe that the system is a gravity fed, gravel lined system. We purchased the home used in the late 90s. I am not certain if the previous owners had similar problems, but for us they started a couple of years after we bought the house.
What happened initially was that the toilet in our downstairs bathroom overflowed (this toilet is the lowest point in the system and the last point before the line enters the septic system.. We initially thought it was a clog, but after confirming that it was not we concluded that the septic tank needed to be pumped out. We had that done and things worked fine for a while.
What continues to occur is that the septic tank becomes full (more on what I mean later) and overflows the toilet fairly often. It has not been on a regular basis but since the first time in 1998 it happens anywhere from almost three years to just under a year apart. When it happens and we have the tank pumped out, the tank is not full as in too much solid waste, but rather the tank is overfilled with liquid waste, apparently because the drain field will not accept any more water. After having the tank drained, the system works fine for another year or more until recently.
Over the course of the years, we have used various companies to do the pump out and they have all generally said there was some problem with the drain field and have recommended various things to try, some of which we have tried. For instance, one time they jetted the line. That did not really seem to have any effect.
In May of 2013 the toilet overflowed and we called to have the system pumped out. This time we were told that out drain field had a problem with biomass. The company recommended the use of their oxidizer plus to eliminate the problem. Since the tech at the time told me that the treatment was guaranteed and would be refunded if it did not work, we gave it a try. (turns out the refund would only be paid in the form of a credit towards the cost of a new drain field. The tech did not mention this, but it was stated in the guarantees fine print, which stupidly I did not read).
In late Dec. of 2013, the toilet overflowed again (this was only 7 months and the shortest time period we had ever had). We called the same company back to pump it out again. They did so and told us that we needed a new drain field. They began the process of soil testing, getting a permit, etc to be able to provide us with our options. They did not charge us for any of the testing, permits, etc.
Two days ago (1-18-14) the toilet overflowed again and the septic tank was full (of water) again. I had it pumped out and they were able to provide me with an estimate for a new drain field. It seems high and I am not sure that everything they say is needed is actually needed, but I am getting some estimates from other companies.
According to the soil test, the only area in my yard that will allow a drain field is the front yard where the current system is. One of my questions if the drain field is no longer viable how can they install a new one in the same place? In doing some research it seems that most if not all states (and I believe Georgia where I live) require that when you get a permit for a septic system, a reserve area for a new drain field is required. This does not appear to have been done in my case.
What causes a drain field to fail? What wears out or is no longer usable? Is there a way to test to see if the drain field is no longer viable?
Could there be other causes of my symptoms?
I appreciate any help or advice.
