Looking for a 1 way on/off valve
Discussion in 'Showers and Tubs' started by Johny22, Jun 17, 2019.
  1. Jun 17, 2019 #1
    Johny22
    Johny22
    Johny22
    Jun 17, 2019
    Toronto
    Guys,
    I recently broke apart my shower and one particular fitting I really could not take apart from the pipe, so I'm thinking to just simply replace it. Having a really hard time finding this.
    My shower might be a bit complicated, but I have the following set up:
    1. Rainfall shower at the top
    2. 4 jets that just shoot out from the wall
    3. Handheld showerhead which a on/off switch
    4. A mixing valve for temperature
    5. Divert valve from handheld to the rainfall, and to the 4 jets
    The problem is, the on/off valve for the handheld showerhead is also the main on/off for the shower. So I installed a simple copper male pipe which now sticks out (sealed temporarily), but ultimately i need an off/on switch with 1 simple spout that i can connect to a handheld showerhead. But that on/off spout needs to actually be sealed 100%, not some cheap plastic that i see in home depot as it doesn't seal and the pressure from the shower water ends up leaking... given this is my main switch, i need it to work 100%.
    Does anyone know where i can find something like this? So basically an on/off switch with 1 spout for a standard handheld showerhead.
    Thank you
  2. Jun 17, 2019 #2
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    774
    145
    NOKESVILLE, VA
    Pictures of what you have would help
  3. Jun 17, 2019 #3
    Johny22
    Johny22
    Johny22
    Jun 17, 2019
    Toronto
    This is basically the fitting/valve i need to replace... simply lever that turns the water on with a spout that i can connect a showerhead to.
  4. Jun 17, 2019 #4
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,347
    203
    Boston, Massachusetts
  5. Jun 17, 2019 #5
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,347
    203
    can you contact the manufacturer
Share This Page
