I too am scratching my head on that moisture meter going through the material. If he hit a grout joint, sure, I could see moisture wicking up from the pan via the grout. That would be normal. Is this how he is determining moisture?
Nothing..just happened few days back..I noticed a wet spot on the ceiling below. The pros think water got in there somehow and was small enough and just accumulated. We checked all the supply lines and everything looked fine and dry.You had the remodel done 1+ years ago and it just started? Was something damaged/altered?
If you want to redo the tile I say go for it - BUT fix the leaking fitting while you have everything apart
Only the spot where the wet spot was...the rest of the ceiling looks fine ..and the joists and sub floor on either side of the opening look absolutely dry. The Infrared scan confirmed it tooHas the ceiling been opened up to see where the water is coming from?
Yeah..it was one of them Restoration company techsI too am scratching my head on that moisture meter going through the material. If he hit a grout joint, sure, I could see moisture wicking up from the pan via the grout. That would be normal. Is this how he is determining moisture?
So to all your expert eyes does it seem plausible for a small leak (say from bench) to pool over time and then make its way to around the drain and leak out of there (see pic earlier)? That spot and nowhere else?
Not sure..don't think hot far as I would have remembered..I am thinking the kerdiWhat substrate do you have under the tile in the shower? Kerdi, Schluter, solid pan, hot tar?
The bench is roughly 14 inches from the drain. Nothing was altered etc..and other than the occasional drop of the shampoo bottle etc..nothing heavy ..the wall and bench are subway tiles..but the floor tile is this rougher jagged design...may be a crack somewhere..everything visibly looks fine thoughThe easiest answer is typically the right answer...
Was the shower used regularly?
Nothing has been altered/damaged/dropped on (edit) before it started?
You do not see any cracks in the tile/grout?
Where is the bench in relation to the drain (distance)?
Where is the drain in relation to your valves?
Not saying it's impossible, although very improbable, but if the shower has not been used for a week and it's still dripping I'd be looking for a pipe/fitting/ connection
Also, the valves are about a foot or so from the drain. Behind that is the toilet room. All those areas look dry as does the corresponding spot below on the ceiling.The easiest answer is typically the right answer...
The dripping hasn't stopped. Feels slower but still leaking...Yeah, the folks are coming over to review options. We haven't shut off yet...but at this point, with nearly a week of no shower use, we are thinking it is a supply line issue but have to open up a few spots to see. It does seem like a tiny leak that is taking a very specific path to leak.Another few days, did the dripping stop? Another thought, are there accessible shut-off valves for that shower/bath? Did you shut them off?
Hoping so! The supply lines are on the vertical wall obviously..and the leak is through the floor..this darn leak seems to have found a path of least resistance...plausible???Yup, supply line fitting... (much "less expensive" than a retile :O))
Yeah...but one would expect spots where the supply lines are to show some wetness, right? ..unless it travels from vertical lines along the floor to the drain..if water is trapped there ..perhaps does need time to trickle outThis is simple......if no water is used in the shower the leak should stop.
if it never stops then it’s the water pipe.
simply not using the shower for a while will tell you what’s leaking.
I wouldn’t expect anything. I just wouldn’t use the shower and see if it stops dripping. SimpleYeah...but one would expect spots where the supply lines are to show some wetness, right? ..unless it travels from vertical lines along the floor to the drain..if water is trapped there ..perhaps does need time to trickle out
