justhisgye
- Joined
- Jul 30, 2022
- Messages
- 3
- Reaction score
- 0
I was on the phone to the water board and I was advised that I am using far more water than I should and that I should check for a water leak. I turned the boiler off and took a meter reading and waited half an hour and took another reading. The difference between the 2 readings was 85. I turned off the mains supply and took 2 (identical) readings 30 minutes apart. The water board advised that 85 means 85 litres and the results of the readings indicates that the leak must be internal to the property and that I need to call a plumber.
I cannot hear any dripping or see any evidene of a leak on the property. My brother said the leak must be underground and therefore responsibility is with the water board or a faulty meter which is also responsibility of the water board.
If anyone can shed any light on this I would be very grateful. Thanks - and thanks for accepting me as a member!
