Bird Doo Head
Hello All!
I purchased a new 4" centerset for a lav vanity sink. When I removed the old drain body, I noticed that the beveled washer that is sent up to the sink outlet via the lock nut was upside down. The flat part was facing up at the sink bottom, instead of the bevel going into the hole in the sink. (In case I am using the wrong part names, a drawing is attached.)
When installing the new faucet's drain body & flange, when the bevel was facing up as received, the drain leaked quite a bit. I experimented around with ensuring the items were centered & tying various amounts of tightening on the lock nut. It still leaked a lot. I bought a new beveled washer in case I damaged the one that came with the faucet. Again, no luck with bevel up.
Next, I removed the sink (American Standard of some sort of glazed ceramic or porcelain material) flipped it over and looked in the drain hole. I can see that the outlet is somewhat mis-cast. It's also rough and not glazed. Experimenting with the beveled washer in my hand, I could see it can't seal properly in the hole with the cone side up.
I re-installed the drain body with the washer upside down, as was the faucet's drain that I removed. the flat part is touching the bottom of the sink. The bevel is touching the locknut.
Now it leaks a tiny bit. The water appears at the bottom of the lock nut. Again I experimented with various lock nut tightness. No luck removing the last, tiny leak. I tried PTFE tape on the locknut threads. No luck. I also thought about trying plumber's putty or duct seal on the top of the gasket, but wisdom made me wait and ask the experts here.
Have any of you ever encountered such a problem? Do you have any hints or suggestions that I may try?
Thanks For Sharing your knowledge & experience. It's appreciated.
Paul
Paul
