The box at the top is missing the frame piece. I just installed the same one, and purchased the entire unit for about $30 at the orange big box store. That would clean up that installation.
I’ve never seen one that’s 1”.
1.5” yessssss but not 1”.
IMO if it’s 1” then it doesn’t have a washer drain.
I know right! But look at the pic - they are all built that way!?!?
Going back to my original question, what options are there?
Replace the drain with one of the appropriate size.
That's kind of the point - it's on slab and can't be. I was looking for options....
A pump and container. Who drilled that box like that ?
If it’s truly a Levitt house or other mass built tract house, then there are a lot of houses real close that are identical. Have you considered asking a few of the neighbors about their laundry drain set up? Maybe this works. If not you’ll at least get a good idea of what others have done over the years.
Those Levitt houses were built very very quickly and very very cheaply back in the 40s and 1950s. Very few survive in their original configuration because it didn’t work or last into the modern era.
You can also probably place a call to the local city or town‘s plumbing inspector, because if there have been a lot of changes to this set up over the years he would probably know about them.
There were many of these homes around where I grew up on Long Island in New York, and they all started with radiant heat buried in the concrete slab... so Jackhammering up concrete might buy you more trouble than you are expecting.
Extending sympathies. I like Mitchell-DIY-Guy's suggestion about contacting the plumbing inspector, so you don't have to come back out later.
