Korky tank replacement kit doesn't fit
nho1989
Dec 3, 2020
United States
I tried to use korky quietfill platinum, but I can't seem to get the tank to sit back properly.
Below is what my toilet looks like. Can someone point me to the right kit(or tell me if I can make this one work). Thanks in advance.
Look on the inside back wall of your tank.
Printed or molded in the china will be lots of info about your toilet, including model number etc.
Post a pic or write it all down here.
Also post the brand of your toilet, usually printed down by the seat hinge.
Your toilet looks to need a special gasket, maybe the Korky can work or maybe not.
A round gasket will probably not seal an oval hole.
That squirrelly white gasket probably has to be ordered from the manufacturer.
Your goofy hole molded into the bowl to receive the base of the flush gasket is a weird oval shape.
Post your toilet info.
Your tank bolt gaskets and washers and nuts are not installed properly.
Watch some YouTube videos.
Are you re-using old parts?
