Not proud to say so but I have a Kohler Pompton series toilet w/ the "New Style" valve body (fwiw). Some time back, I noticed water leaking into the bowl. The back of the bowl had the tiniest amount of flow coming in from the top. So, I went to the specialty supply house (can't get Kohler parts at HD or Lowes or Ace TV) and bought a new flapper. I replaced it and still, the micro-leak continued.
So, thinking the float valve wasn't stopping the water flow, I bought a valve rebuild kit from an on-line outfit and carefully rebuilt the valve itself. I put it all back together and still the %$@*^! leak continues.
It turns out that there's a cast hole between the tank and the bowl up under the back rim. It appears that water is coming from back to front through that hole - as though the water level keeps on rising in the tank (ever so slowly, mind you).
Does anyone have any experience w/ this particular toilet series (Pompton), and in particular w/ that leak syndrome? I'm wondering where else could be the source of this leak.
