Hi everyone. This is my first post. I thought I would probe a forum to see what kind of opinions I get.
I own 2 condos in San Jose CA. One is on the 1st floor and the other is on the 4th (top) floor. The 300 condo complex was built in 2007. Each unit has two bathrooms with each master having a separate shower and shower/tub. The valves consistently fail which makes it impossible to modulate the water tempura the during a shower or bath. I have had 3 kohler PBV and mixers replaced professionally (at $200/invoice) and I have replaced 3 myself between the 2 units. I have notified the HOA but they keep saying its the owners responsibility. I believe there may be some sort of sediment that keeps clogging the valve.
If it's of any importance, they HOA has recently installed a water softener for the complex. I also noticed the valves tend to fail if the valve is not used as often.
My questions are:
1 Is this a common problem and should I expect to replace it often?
2 Could it just be the quality of water?
3 Is it really my responsibility or should HOA have some sort of filter?
4 Could this be a warranty issue with kohler?
Any comment or suggestions and are greatly appreciated.
Kevin
My questions are:
Kevin
