Kitchen Sink with Garbage Disposal and dishwasher
PrecisionPlum
Supporting Member
Jul 9, 2017
90
9
Kitchen Sink with garbage disposal and dishwasher:
I always rough in a double bowel sink with two 1-1/2" drains. One for the dishwasher and
garbage disposal (Dishwasher discharges directly into the GD). I do this because I figure a
horizontal drain to a Tee would not be enough to handle the DFUs. I allow two DU for the
sink with the GD and two for the dishwasher. I do this because I figure both can be discharging
at the same time. Though I admit this would rarely happen. A fellow plumber says I'm over
doing it. He runs a horizontal drain from the GD into a Tee under the other sink bowel and
roughs in only one 1-1/2" drain.
Am I over doing it?
Your thoughts on best practice?
TYA
2 traps. Make sure the garbage disposal is coming into the top of the tea, or use a y, so the blast from the disposal doesn't blow water up the other sink.
Tim Whistler
Tim Whistler Plumbing & Gas
Tim Whistler
Looks like you stepped the lines up to 2" and have an AAV at the top of drain.
For the sink drain, did you use a sanitary Tee on its side?!
As for a separate drain for the GD: If it is a new rough in, I think I'm going to
keep installing a separate drain for the GD.
Thanks for your feed back Tim.
If you do much service work you are going to find the disposal kit more that 2 seperate drains. I ran mine
like you do.
I would’ve stacked the tee’s with Disposal tee on the bottom. I typically won’t lay a san. tee on it’s side or back.
The traps as the are now are not vented properly. It’s two traps on one fixture arm with a vent. You’d need a vent between the two traps.
But what’s pictured will function.
