I replaced my kitchen counter with a granite slab and installed a Kohler Apron Stainless Steel Kitchen Sink (under mount). I love the sink but I have a pesky problem with the way it drains water. Most sinks have a slope that drains water towards the hole (in-sinkerator) but the surface of this sink is absolutely flat. The debris/leftovers from plates and dishes stay scattered around the sink and I end up wasting a lot of water by using the faucet spray to move the debris from the periphery to the drain hole. I ended up buying a squeegee to move the debris but it's a pain as I have to lift the grate every time I do dishes.
Is the design defective or has my plumber not installed this correctly? Is there a way to fix this without having to uninstall the sink? Since it is an under mount re-install with a different sink is a non-starter. Appreciate your help.
