Kitchen Faucet Removal Dilemma
Discussion in 'General Plumbing Help' started by PiReggie, Aug 22, 2019.
  1. Aug 22, 2019 #1
    PiReggie
    PiReggie
    PiReggie
    Aug 22, 2019
    El Monte, California
    I am replacing my kitchen faucet but run into some trouble. I am having a hard time removing the center part of the faucet under the sink. I included a couple of pictures. I tried unscrewing it by hand as i did the other two, but it won't budge. The nut seems like is encased in this black plastic thing. I tried prying it off so i can get into the nut but no luck at all. Does anyone have any suggestion on what i should do?
    [​IMG][​IMG]
    Ps. I did not install this.
  2. Aug 22, 2019 #2
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    414
    87
    You may wish to try a basin wrench.
    Also, spray some penetrator on it and let it sit for awhile.
  3. Aug 23, 2019 #3
    PiReggie
    PiReggie
    PiReggie
    Aug 22, 2019
    Thank you for your reply. How do i get the black part out to get to the nut? I tried prying it off it wont come off.
  4. Aug 23, 2019 #4
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    414
    87
    Not sure bUT I think the black plastic and nut will unscrew together using the basin wrench.
  5. Aug 23, 2019 #5
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    215
    38
    Chicago suburbs
    Yes, looks like the black plastic part is just fitted over the nut, one should turn with the other.
    You could pbly just tap a flat blade screwdriver between the two, and twist it, which might crack the plastic so it can be removed.
    Be careful not to bang up the sink with the screwdriver.
    As Jeff said above, a few sprays of penetrating oil will help break the plastic and the brass nut free from that rusty junk.
    Looks like you have enough room to get a pair of channel lock type pump pliers on it.
  6. Aug 23, 2019 #6
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    215
    38
    Chicago suburbs
    While you are at it, coat all that long threaded section with oil, that brass nut pbly has to unthread over all that corrosion.
  7. Aug 26, 2019 #7
    PiReggie
    PiReggie
    PiReggie
    Aug 22, 2019
    Thank you for your replies, I really appreciate it. I have solved my problem. I rented a reciprocating saw from home depot and just saw the old faucet off. I tried uploading the photos here but it says its too big of a file. So I just added it to my media. Thanks again for all the suggestions.
  8. Aug 26, 2019 #8
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,509
    2,347
    use your dremel tool with a cut off blade
    cut the nut into, then spread it with a screw driver
Share This Page
