Keeping Old Waste/Overflow
Brdkey
Oct 17, 2019
7
SC
So today I took the drywall out in the room behind my bathtub. My waste and overflow pipes are concreted into the slab. Is there a way to keep the old pipes or do the waste and overflow pipes have to be replaced? Also I have attached a picture of what it looks like. The concrete mixed around the pipes seems to be more of a gravel mix and I believe my drain pipes are galvanized steel.
johnjh2o
Professional
Lifetime Supporter
Jul 21, 2011
3,328
772
Melbourne, Florida
If your replacing the tub you may have to replace it, as the drain on the new tub won't be in the same location.
Brdkey
Oct 17, 2019
7
SC
Do you have any advice as far as the process goes? My friend has an angle grinder with a diamond blade he said I could use to cut around the drain that's concreted in. What steps do I need to do after that? It doesn't have to be filled in correct? Also is there a way to go from a PVC drain kit and attach it to the metal drain pipes already existing.
